ESP Warning Light
Old 07-23-2016, 06:47 AM
AudiESP's Avatar
Exclamation ESP Warning Light
UPDATE:Got problem sorted,changed the ABS Control Unit.ESP Warning light now gone.
Hi All,
Hope you's can help,im new to the forum.
I have an Audi A3 2003(newer version) 1.6 petrol.I had been having problems with my battery for a few months,always started eventually,never had to jump start.Then the ESP lights came on a few weeks back.Taught when i replaced my battery that it might go away.Got a new battery last week,fella in the motor factors checked my old battery and said it was running at 90.So brought the car to a local mechanic last week for the diagnostic to be run,he said it more than likely be a fuse,or a wire cut somewhere.Left the car with him for the day,when i collected it in the eve,he said the diagnostics didnt run properly,wasnt reading? Only got one fault code 18057.and he also checked fuses,all ok.
Ask would i bring the car back yesturday,as there would be a different mechanic in on friday his cousin from different garage.And that he is a whizz kid with software and has his own diagnostic machine and knows audi's inside out.And that he would trace all wires behind battery to see if any broken.
So brought car down yesturday,got a call at 3pm from first mechanic to say they think i have a problem with my ABS Unit its running at 284mph and it should be at zero and that it might need to be repaired,said a place in dublin does repairs and it would cost roughly about €400-500 plus labour,and he would ring Logic Motives to confirm price,but he could not get through to them no answer all day.
And also the mechanic that looked at the car today had an appointment and had to go so i never got the option from him to remove the unit.
Asked how much it would be the the software whizz kid thats knows about audi's to remove and replace unit and the other mechanic said he would find out and let me knew cost and when he would be back to there garage,as they could not put ABS unit in.Still waiting to here.
Asked would it be possible to get second hand ABS Unit,and he said it would have to be the same numbers? and that i wouldnt be able to get one.
I have no other warning lights on car and its running fine.
My brake lights are working ok,seen this mentioned before on forum.
Just wondering has any body else had this problem,with just the ESP warning light coming on and not the ABS as well?
Want to make sure im changing the right with the cost going to be about €700+.Car has failed NCT because of the light and the garage said it cant be cleared.
I would be greatful if anybody could shine some light on this.
Thanks for reading,sorry if i rattled on a bit.
teecee
06-04-2007 11:04 AM
RodCouncil
03-13-2007 12:44 PM
PMONT
03-22-2006 01:31 PM
Quick Reply: ESP Warning Light
