grunt noise from brakes
Old 06-19-2009, 10:49 AM
tedman's Avatar
Default grunt noise from brakes
my 2005 s4 cab. auto trans produces a grunt noise from the brakes everytime car comes to a full stop, and when the brake petal is released from a being stopped. Any advise?
Old 06-21-2009, 10:28 AM
vernk's Avatar
the brakes are just very grabby....its not really a problem as it is a nuissance. if it bothers you that much you can try to have the rotors resurfaced and/or replace the pads. if you drive spiritedly...is that a word? you could polish up your rotors and have heat marks. the brakes will be a bit more 'grabby' like this. a cleaner/smoother mating surface will fix it up. but if you continue to drive like you do....it'll happen again
Old 07-02-2009, 03:24 PM
tedman's Avatar
Thanks,the car is still under warranty, do you know if this will be covered by audi.
Old 07-03-2009, 10:48 AM
ImTheDevil's Avatar
Keep in mind the brakes are vacuum-boosted. There's a chance you have a slight vacuum leak and you're hearing a "fart" when you hit or release the brakes. It's a slight chance but keep it in the back of your mind.
cekren
08-18-2013 12:14 PM
jcA4Quattro
04-08-2012 10:22 AM
tedman
06-19-2009 04:58 PM
S4Colorado
10-01-2007 12:20 AM
comfortstyle
11-01-2006 03:23 PM
Quick Reply: grunt noise from brakes
