Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Removing Door Panel
Old 02-21-2007, 11:27 AM
hannesr's Avatar
Default Removing Door Panel
Hey guys how do i remove door panel?? Here are some pictures of the screws i found (and tried unscrewing, where one screw ended up not being able to be put back in properly )
Can someone please tell me how i could remove the door panel??
Old 02-21-2007, 01:50 PM
hannesr's Avatar
Default RE: Removing Door Panel
Update: Found 2 more screws, however when i unscrewed i couldnt get anything off
Old 02-22-2007, 05:38 AM
TeeterTawter's Avatar
as i do not know what type of audi you have, this is how u remove the panels in the B5 A4, remove the 2 black screws in each corner as shown in the pic, remove the screw inside the handle/arm rest as shown in the pic, and that inner piece should slide down. then remove the 2 bolts/screws that apear after the inner piece of the door handle/arm rest, and carefully pull up on the panel and presto. heres an article as well on it http://www.audiworld.com/tech/int13.shtml
[IMG]local://upfiles/15922/EB14CB3E980446A7B7B96DE847306CB5.jpg[/IMG]
[IMG]local://upfiles/15922/5ED7D75DC0684F408202F6F731B367DB.jpg[/IMG]
[IMG]local://upfiles/15922/57DAB68B2CA548ABA8524CF4077C55E1.jpg[/IMG]
[IMG]local://upfiles/15922/5D1DF36E56734DAF8CA4616A3C472BAB.jpg[/IMG]
Old 02-22-2007, 05:42 AM
damn error.
[IMG]local://upfiles/15922/B5B338ED09594055849F153A45318187.jpg[/IMG]
[IMG]local://upfiles/15922/1DBF013C22D64D3B9D7455A8960649E4.jpg[/IMG]
[IMG]local://upfiles/15922/8A0F6716FB574B3C9FE37944721139C2.jpg[/IMG]
[IMG]local://upfiles/15922/990CFC5CC7A6401EBC491451AB164EFD.jpg[/IMG]
Old 02-27-2007, 07:27 PM
hannesr's Avatar
thanks alot on your reply.. but if i remove the screw under the handle and remove the electronics, no new screws appear! where are they??
Old 02-28-2007, 03:13 AM
if u dont mine me asking, why do u want to remove ur door panels for?
and i believe u have an A3, i dont know much about those cars as i have NEVER been in one, best thng for you to do is to post in the A3 room and ask the same question on how to remove the door panel. whats a good investement is the bently manual, will tell u EVERYTHING you need to know about you car.
Old 02-28-2007, 10:15 AM
hannesr's Avatar
i want to add some wires to add a light into the door pocket.. Oh right ok will post it in that forum... and will read up on the bently manuals! thanks mate!
Old 03-02-2007, 07:18 AM
BadLuckAudi's Avatar
under the other part of the door handle are two screws where you grab to open it
Old 03-02-2007, 09:55 AM
hannesr's Avatar
yeah cheers guys i got it sorted! just the two screws, remove the electrical cables from the handle part and then just lift the hole door and pull out. quite simple actually!!
Old 12-08-2014, 08:15 PM
Jazatazz's Avatar
Default removing driver's door panel A4 2003
Hi. Just need a little advice or clarification on the 2 screws under the arm rest. Are they the only two screws to remove before lifting the panel off? I don't want break anything. Thanks
Jackmup
04-25-2009 11:16 PM
rollyfoster
04-16-2009 04:32 PM
RadRup
08-11-2006 11:38 PM
dlinbh
01-10-2006 01:10 AM
specialK4
12-29-2005 01:56 AM
Quick Reply: Removing Door Panel
