Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Removing Door Panel
Old Feb 21, 2007 | 11:27 AM
hannesr's Avatar
Default Removing Door Panel
Hey guys how do i remove door panel?? Here are some pictures of the screws i found (and tried unscrewing, where one screw ended up not being able to be put back in properly )
Can someone please tell me how i could remove the door panel??
Old Feb 21, 2007 | 01:50 PM
hannesr's Avatar
Default RE: Removing Door Panel
Update: Found 2 more screws, however when i unscrewed i couldnt get anything off
Old Feb 22, 2007 | 05:38 AM
TeeterTawter's Avatar
as i do not know what type of audi you have, this is how u remove the panels in the B5 A4, remove the 2 black screws in each corner as shown in the pic, remove the screw inside the handle/arm rest as shown in the pic, and that inner piece should slide down. then remove the 2 bolts/screws that apear after the inner piece of the door handle/arm rest, and carefully pull up on the panel and presto. heres an article as well on it http://www.audiworld.com/tech/int13.shtml
[IMG]local://upfiles/15922/EB14CB3E980446A7B7B96DE847306CB5.jpg[/IMG]
[IMG]local://upfiles/15922/5ED7D75DC0684F408202F6F731B367DB.jpg[/IMG]
[IMG]local://upfiles/15922/57DAB68B2CA548ABA8524CF4077C55E1.jpg[/IMG]
[IMG]local://upfiles/15922/5D1DF36E56734DAF8CA4616A3C472BAB.jpg[/IMG]
Old Feb 22, 2007 | 05:42 AM
damn error.
[IMG]local://upfiles/15922/B5B338ED09594055849F153A45318187.jpg[/IMG]
[IMG]local://upfiles/15922/1DBF013C22D64D3B9D7455A8960649E4.jpg[/IMG]
[IMG]local://upfiles/15922/8A0F6716FB574B3C9FE37944721139C2.jpg[/IMG]
[IMG]local://upfiles/15922/990CFC5CC7A6401EBC491451AB164EFD.jpg[/IMG]
Old Feb 27, 2007 | 07:27 PM
hannesr's Avatar
thanks alot on your reply.. but if i remove the screw under the handle and remove the electronics, no new screws appear! where are they??
Old Feb 28, 2007 | 03:13 AM
if u dont mine me asking, why do u want to remove ur door panels for?
and i believe u have an A3, i dont know much about those cars as i have NEVER been in one, best thng for you to do is to post in the A3 room and ask the same question on how to remove the door panel. whats a good investement is the bently manual, will tell u EVERYTHING you need to know about you car.
Old Feb 28, 2007 | 10:15 AM
hannesr's Avatar
i want to add some wires to add a light into the door pocket.. Oh right ok will post it in that forum... and will read up on the bently manuals! thanks mate!
Old Mar 2, 2007 | 07:18 AM
BadLuckAudi's Avatar
under the other part of the door handle are two screws where you grab to open it
Old Mar 2, 2007 | 09:55 AM
hannesr's Avatar
yeah cheers guys i got it sorted! just the two screws, remove the electrical cables from the handle part and then just lift the hole door and pull out. quite simple actually!!
Old Dec 8, 2014 | 08:15 PM
Jazatazz's Avatar
Default removing driver's door panel A4 2003
Hi. Just need a little advice or clarification on the 2 screws under the arm rest. Are they the only two screws to remove before lifting the panel off? I don't want break anything. Thanks
Jackmup
Apr 25, 2009 11:16 PM
rollyfoster
Apr 16, 2009 04:32 PM
RadRup
Aug 11, 2006 11:38 PM
dlinbh
Jan 10, 2006 01:10 AM
specialK4
Dec 29, 2005 01:56 AM
