Fuel delivery problem
Old Jun 29, 2009 | 02:46 PM
audidude89's Avatar
Default Fuel delivery problem
2000 Audi S4. Every once in a while, if I leave my car idling for a few minutes, the car starts to shake sort of. But when I give it a little gas in neutral for a few seconds, or i put it in gear and drive for a short distance, it stops. Ive been having this issue for a couple weeks now. I have replaced the fuel filter just a couple days ago and its still doing it. At some points the car wont even start. It turns over fine, just doesnt start until I pump the pedal numerous times and then it slowly comes back to life. I have absolutely no idea what it could be now. i was almost sure the fuel filter would cause it but i was wrong. any help or ideas would be great guys. thanks alot
Old Jun 29, 2009 | 04:30 PM
Mott Power's Avatar
Could be the fuel pump or, kind of a long shot, the pressure regulator.
Are you getting a CEL or are any codes popping up? I don't think the pump has a sensor that would throw a code, so if there is none then I would start by looking there. I could be wrong about that though.
Old Jun 29, 2009 | 05:48 PM
audidude89's Avatar
well yes the CEL is on but its on because I removed the electronic governor off the car. How hard is it to replace the fuel pump and where is it located? that might be the next part I replace to try and fix the issue
Old Jun 30, 2009 | 01:47 AM
Mott Power's Avatar
http://forums.audiworld.com/showthread.php?t=1480614
this is a good write up about how to take one out.
they are almost always on top of the fuel tank and accessable through the trunk.
i would also be skeptical of your MAF sensor, bad ones usually share the same symptoms of a rough idle, hard start ups, etc. if you haven't changed the stock one out, this would be a good first solution, seeing as they almost always go out on B5 S4's anyways.
Old Jun 30, 2009 | 07:37 PM
deephouse's Avatar
Do the B5S4s have a ISV? (Idle stabilazation valve)?
something to check if so.
Old Jun 30, 2009 | 10:07 PM
audidude89's Avatar
UPDATE........ Took my s4 in today and had it run through the computer. It turns out that valve 6 isnt firing. Its an on and off issue that is solved temporarily by pushing on the gas. Ive narrowed it down to a bad fuel injector in that valve. all in favor say "aye" haha. if not, what do you think?
Old Jul 1, 2009 | 02:04 AM
Mott Power's Avatar
it's just not firing or it's misfiring? if misfiring it could be a coilpack, switch one with another and see if that cylinder has the same problem
austinwasthere
Mar 28, 2011 09:33 PM
austinwasthere
Mar 28, 2011 03:02 PM
Prizmatik
Oct 20, 2009 04:36 PM
bleak17
Mar 16, 2008 12:00 AM
daz
Aug 31, 2005 05:01 PM
