Need help....please...
Old Sep 17, 2009 | 09:46 PM
2.7TALLROAD's Avatar
Default Need help....please...
have a 2001 allroad my aux. fan stopped working ...wondering if anyone knows where the relay or fuse to it are....and my a/c stops cooling at idle wondering if it might be because of the fan...it works fine if you are driving but as soon as you stop at a light it stops cooling please help if you have had this problem or know how i can fix...motor only has 59k
thanks in advance for any help i tried looking for the relay but could not find it...all the fuses on the driver panel are good..unless there is other fuses i do not know about....again if you can help i appritiate it...don't want to take it to dealer as they will probably want to change the whole motor...lol....EXPENSIVE...
Old Sep 19, 2009 | 02:58 PM
ertatta's Avatar
i had this very problem about a month ago! took it to the dealer after work hours while mechanics were still there and they took a crow bar and banged at the fan motor about 6 times. this seemed to loosen up some buildup(dirt/grime) and voila, the fan starting working and the car was back to cooling like a champ! give it a try and let me know!!!
Old Sep 21, 2009 | 05:47 PM
thanks for the tip ertatta...i tried it and it worked....i think i might need to change it soon though as i saw alot of tiny metal shavings coming out of the motor... ....anyhow thanks again for the tip.....
Old Sep 23, 2009 | 04:36 AM
ertatta's Avatar
glad to hear it worked out! so the AC is back to cooling?
Old Sep 25, 2009 | 05:51 PM
yep so far so good....the only thing i have not been able to reset is the air bag light on the dash it came on several weeks ago and have not been able to reset it i tried disconecting the battery and also tried the vag.com and nothing... guess its going to have to take a trip to the stealership....
