A4 2.8 coolant leak
Old Jan 3, 2010 | 03:04 PM
sportsbum30's Avatar
Default A4 2.8 coolant leak
I've read several posts about the coolant flange on the 1.8t engine leaking. Is this common in the 2.8 engine as well. The oil pan as well as bell housing on the transmission seem to be collecting coolant which seems to point to the coolant flange. It looks like the flange on my brothers 2.8 (who i'm trying to help) is extremely hard to access. I can't really even get a hand on it. Any help would be appreciated as the car is leaking enough fluid to render it undriveable.
Old Jan 3, 2010 | 03:11 PM
dragonrage's Avatar
If it's the same plastic crap then it'll have the same issues.
Old Jan 3, 2010 | 08:53 PM
It is the same plastic crap it's just really hard to get to. The engine bay in the 2.8 is obviously a little more crowded than the 1.8T. Just wondering if anyone has had the same problem because I cannot easily get to the flange.
Old Jan 3, 2010 | 10:32 PM
Mouse4's Avatar
Look for a post by me a few months ago. I ran into the same issue with my 2.8. Be extremely carful when removing the other end of the hose. The heater core nipples are very, very, very, brittle. Mine broke and I had to put a new heater core in. You don't want to do a heater core. It was hell.
It is very tight back by the firewall. I had to cut a few of the ties that held in hoses and wires. I removed the plastic intake duct that was bolted to the engine. I think it was two bolts and pulled out. That gave a just enough room to get to the clips and pull the hose off. Remember, be very carful when taking the other end off the heater core nipple. It's made of plastic and if never changed, it will be very brittle.
Old Jan 4, 2010 | 02:00 PM
Thanks for the head's up mouse. I found the old post. Looks like my brother probably has the exact same problem.
Old Jan 4, 2010 | 05:28 PM
hiwords's Avatar
you can pretty much access the top of the flange if you took off the hard plastic intake pipe. it's the screw on top of it and i believe 2 or maybe 1 allen bolt on the throttle body and it comes off.
Old Jan 4, 2010 | 08:39 PM
ImTheDevil's Avatar
Yep, one allen bolt on the throttle body - you have to find it by feel since you'll never see it with the way it's positioned.
Old Jan 5, 2010 | 04:06 PM
thanks for the responses. I'm probably going to dig into it in the next couple days or may just have my mechanic do it if the price is right.
Cioffie
May 19, 2013 10:24 PM
azr3al
Dec 30, 2011 12:37 PM
supacor24
Jun 3, 2011 07:56 AM
inventorA6
Apr 15, 2009 06:46 AM
less_of_me
May 2, 2007 03:29 AM
