Sick Audi.....
Old Oct 2, 2005 | 01:32 PM
nemo2182's Avatar
Default Sick Audi.....
Ive recently had my car diag tested and these were the results. The car should be running at 210BHP, but its running ***** at mo, hence getting the test done. Can anyone tell me were to start and whether one error could be having a knock on effect to create the others??I was guna start with Mass air flow sensor?Is there any of these errors that will actually not affect engine performance??Anyways, these are the error codes....
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80) 29-00 - Short to Ground
01262 - Solenoid Valve for Boost Pressure Control (N75) 29-00 - Short to Ground
16486 - Mass Air Flow Sensor (G70): Signal too Low P0102 - 35-00 - -
16519 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit: Malfunction p0135 - 35-00 - -
Any help will be appreciated. I know its pretty much in black and white, but im sure of how to cure the short to ground faults????
Old Oct 12, 2005 | 01:46 AM
Jestnomen's Avatar
6th Gear
Default RE: Sick Audi.....
Have you recently run the gas tank almost dry?
Old Feb 1, 2006 | 12:19 AM
J.J's Avatar
J.J
It is something to do with electricity regulator in Your alternator!! Had a similar problem!! And check your Lambda !!
Old Feb 1, 2006 | 04:04 PM
techbod's Avatar
1 of 3
[IMG]local://upfiles/12092/931D3A3E6E5B4B04A755BCCEF20FE20A.jpg[/IMG]
Old Feb 1, 2006 | 04:05 PM
techbod's Avatar
[IMG]local://upfiles/12092/0931E101A5C64C09B99FE3B2C7D4414F.jpg[/IMG]
Old Feb 1, 2006 | 04:06 PM
techbod's Avatar
#3 of 2 (3) cough reason for edit
[IMG]local://upfiles/12092/1F8EC8E868574350AB320EFCD7AE3649.jpg[/IMG]
Old Feb 12, 2006 | 02:20 AM
zensane's Avatar
i dont what to say because i dont know what model audi is it,possiblity chek the ecu or the chip.
Kozzimo55
Jul 24, 2010 11:56 PM
andy7
Mar 12, 2009 11:02 PM
nemo2182
Oct 2, 2005 02:16 PM
easdem
Feb 7, 2005 07:40 PM
