MOTOR SWAP!
Old Nov 17, 2005 | 01:37 AM
kiddcarbuff's Avatar
Default MOTOR SWAP!
alroht, i have heard of swapping the 2.3 5 cyl out of my 1991 80 quattro for the 100 qt or 200 qt qauttro turbo motor. it looks like the same 2.3 5 that i have now w/ a dif intake manifold and some other odds and ends. also is it swap the motor, hook it up, and plug in the turbo ecm and ur ready to go, i found a motor w/ 100,000 on it from a 200 qt,(2.3, 5cyl turbo) for like 350 at the junk year the car was rolled. any suggestions? i want more power!
Old Nov 17, 2005 | 06:19 AM
Karl's Avatar
Default RE: MOTOR SWAP!
yes its possible to swap the 2.3T for the 2.3 N/A.. this is very common in the Audi 4000 CS.. and a damn good idea!! because you have one hell of an engine in one light *** car!!!
as for the junk yard.. try to get the whole car for 400 as is.. they will most likely go for it.. and you will have all the extra stuff you need, ie computer mounts, plumbing.. wheels extra tranny.. etc etc.. etc.. if that doesnt work, I would highly suggest buying a used one with high miles for cheap. Then you can pull the engine and do a rebuild and upgrade!!
Old Nov 19, 2005 | 09:02 PM
i know the turbo on that motor is the k 24, i want to upgrade it to something bigger and with ball-bearing center. i jsut need to know whta turbos will fit that flange.
Old Nov 29, 2005 | 10:28 PM
alright im in thge process of aquiring the motor, its on a stand now and i want a different turbo, something ball bearing.....what will mount to the flange??? im also trying to get a divv BOV on the thing too. any opinions on what i should use???
Old Dec 5, 2005 | 12:39 AM
ronin23's Avatar
stratmosphere..i have one..they are sick..plus they make a mini sized one depending on your application and space under the hood
Old Dec 7, 2005 | 10:10 PM
they have a website?
slaterjr
Dec 18, 2014 11:41 PM
o0hmikee
Oct 24, 2011 10:19 PM
green18
Dec 7, 2007 05:08 AM
bdub
Dec 21, 2006 03:49 PM
Solow
May 8, 2005 05:44 AM
