Just hardwired my V1 w/pics
Old Apr 3, 2006 | 09:27 PM
kpatz's Avatar
Default Just hardwired my V1 w/pics
I just finished doing a "stealth" V1 install in my 2002 A4 1.8T. Here's some pics to show what I did.
The V1 itself is inside a visor pouch to make it invisible to thieves and nosy cops. I cut holes in the pouch for the wire and the laser sensors.
I was able to run the wire up the A pillar without interfering with the air bags. When I pulled the trim off, there was a hose (probably the drain hose for the sunroof) held in with clips, so I inserted the wire into those clips, so the wire is completely clear of the airbag but is still nicely tucked inside the pillar.
I also found a great place to stick the concealed display. I pulled out the credit card tray in the stereo/climate console and put the display there. It almost looks like it came with the car. See the pics below.
Preparing the pouch. In this pic I have the V1 on top of the pouch, and am in the process of cutting the hole for the front laser sensor.
Here's a Nightshot photo of the V1 in the pouch showing the front laser sensor is visible through the hole.
Here's a hole I cut to expose the rear laser sensor.
This hole is for the power cord.
Here's where I mounted the remote display. It is located between the ESP button and the hazard flashers button, in the top of the cluster.
Here's another shot, with power turned on so the LEDs are lit.
This shows where I wired into the fuse panel.
Here's the pouch in its place. That stack of foam tape and Velcro above the visor is there to shim the visor to make the V1 level.
I mounted a kill switch under the dash, in case I want or need to turn off the V1.
Here's a couple more pictures of the pouch.
Old Apr 3, 2006 | 09:56 PM
pootey's Avatar
Default RE: Just hardwired my V1 w/pics
where did you get that v1 from
Old Apr 3, 2006 | 11:49 PM
kpatz's Avatar
The same place everyone gets V1s from... www.valentine1.com
Old Apr 4, 2006 | 12:08 AM
i3uddha's Avatar
Site Moderator/Ninja
nice pics...
the remote display is very cool...
no offense - but i dont lke the whole velcro & double side tape finish...
looks kinda awkward... but hey - it works right?
Old Apr 4, 2006 | 05:08 AM
Poopie's Avatar
needs a little finishing work but good job hiding it.
Old Apr 4, 2006 | 10:41 AM
kpatz's Avatar
Well, as they say, form follows function. I'll be tweaking it as time permits. I need to fabricate something better to fill the gap between the remote display and the ESP button, and figure out a better (looking) visor shim. Maybe I can just the foam tape jig in tan fabric. The V1 itself is a little crooked too, so I'll have to figure out a way to shim that as well (maybe another piece of velcro).
But hey, it works, which is the most important thing, as in the spring a young cop's fancy lightly turns to thoughts of speeding ticket revenue...
Old May 13, 2006 | 11:12 AM
paulhiggs's Avatar
Great ideas for mounting the V1. All invention is good invention and a great starting place for taking this further.
Elohite
B7 Models
Feb 25, 2008 04:55 AM
jbertha
Aug 6, 2007 08:38 AM
jbertha
May 29, 2007 06:56 PM
05BLACK_S4
Aug 23, 2006 04:21 AM
YFZFourFifty
May 6, 2005 05:10 PM
