MP3 Your Car - HARDWIRED iPod adapter kit
You are looking at a USED Neo ProLink video iPod adapter. RETAILS FOR $199. SELLING NOW FOR $149 plus FREE SHIPPING. PM me for details.
This was installed in a 2004 Audi A4 and removed when it was sold. it is fully functional Please check www.mp3yourcar.com for compatibility questions. This is a great product to get your iPod wire directly into your existing head unit while being able to still use the stereo buttons to switch tracks. It also powers the iPod so you never have to worry about your iPod going dead on a long trip. DETAILS BELOW
The Neo ProLink iPod adapter gives you high quality audio, power and charging of the ipod as well as control on the radio and steering wheel (if equipped). When the iPod is connected, you will have full control on ipod from the iPod itself, your iPod and screen will NOT be disabled when connected. You will be able to access and use the menu, click wheel, track and play/pause buttons. There is no special playlists that need to be setup, and you are not limited in anyway. You will have access to your entire music collection from playlists, artists, albums, songs and genres. This adapter also has an AUX port on it so that you can connect a DVD, SAT, or any audio device of your choice.
How it connects:
The Neo ProLink kit includes a cable that plugs directly into your iPod. The cable on the other side of the kit plugs directly into your vehicles radio β there is no FM modulation. You get crystal clear, CD quality sound all while retaining the clean look of your factory stereo all with one simple cable that connects, controls and powers your iPod. It always keeps your iPod charged and ready to go. The Neo ProLink, replaces all previous adapters by adding more features, functionality, better sound quality and the ultimate in ipod to car performance and integration. This is the best iPod car adaptor kit available on the market using the highest quality components.
Features:
[ul][*]Direct Connect - iPod plugs directly into the car radio.[*]Power and Charging β Powers iPod and charges battery when iPod is not in use.[*]Track Control β Change iPod songs from buttons on car radio.[*]Steering Wheel Control β Buttons will control iPod (track, volume, etc)[*]High Quality Audio β CD quality audio or better (depending on your audio files bitrate)[*]iPod pauses when not in βiPod modeβ, once car or radio is turned off, iPod will shut off and go into charge mode. [/ul]
Use and Control:
iPod Control on iPod:
[ul][*]Direct use of iPod and control of every playlist, song, artist and menu setting β iPod screen, menu and wheel are NEVER locked out. [/ul]
iPod Control on Radio:
[ul][*]Radio buttons can be used to access ALL of your playlists, as well as albums, etc. You can jump through your playlists and access an unlimited amount of songs. Use the iPod or the radio, its your choice! [/ul]
Additional Features:
With the Neo ProLink, we have added a 2nd device input to our adapters that is an auxiliary input. Now you can not only connect your iPod but also connect: CD, DVD, Mp3 players, aftermarket satellite radio, or any audio device in conjunction with the iPod. Switching between the iPod and the AUX input is done by the push of a button.
What iPods its compatible with:
The Neo ProLink is compatible with all iPods with a dock connector on the bottom. If you charge your iPod by plugging it in from the bottom, your iPod is compatible.
Additional Vehicle Compatibility Information
[ul][*]In-Dash CD Changer is not affected or disabled. It will function as normal.[*]Must have CD-Changer prewire usually found in trunk, glove box or center console (13-pin round plug). If equipped with CD Changer, it MUST be disconnected.[*]Factory Navigation radio IS compatible.[/ul]
How it connects:
Features:
Use and Control:
As far as I know, yes this will work with Navi. It simply plugs into your stereo harness. Just remember to turnt he car off and take the keys out of the ignition before installing. The hardest part of this installation is getting behind the stereo. Aside from that, it should take you all of 3 minutes.
email me if you have more ?s or are interested in the purchase.
joe.bertha@gmail.com
If it has the same connection as an iPod I would say it will work. Check out www.mp3yourcar.com for more details.
jbertha
May 29, 2007 06:56 PM
