A6 Ashtray removal
Old Nov 30, 2004 | 01:46 PM
reptar's Avatar
Default A6 Ashtray removal
Can anyone advise how to remove the front console ashtray assembly in an A6 Avant model - 97.
Need to re- assemble tilting cig lighter, has popped out.
Old Nov 30, 2004 | 02:19 PM
reptar's Avatar
Default RE: A6 Ashtray removal
forgot to add model is 97 onwards
Old Nov 30, 2004 | 04:04 PM
Jestnomen's Avatar
6th Gear
do you have a pic of the ashtray?
On the a4's you pull out the little tray inside. Open the ashtry half way and you can see two little metal tabs, one on each side. You take two screw drivers and press them down and the whole assembly pulls out.
Old Nov 30, 2004 | 04:51 PM
reptar's Avatar
Thanks for the reply - yes I had an A4 previously, and this was the case.
A6 does not seem to conform to the same design ??
Trouble is the plastc is so fragile, that I am trying to get sound advice before forcing what i believe to be tangs or clips.
Thank again.
PRC
B7 Models
13
Nov 23, 2011 01:36 PM
CAPE A4
Nov 9, 2011 11:12 AM
ZinC4
Oct 9, 2009 05:51 PM
proxeyed
May 6, 2007 01:00 AM
lilmonkey
Nov 12, 2006 03:36 PM
