A6 temp Gauge intermittant
Old Dec 25, 2004 | 10:58 AM
powerboat's Avatar
Default A6 temp Gauge intermittant
My A6 Quattro 2.8 1999 has a temperature gauge problem.
It shows cold car, when it has to show normal temp.
Then every 2 -3 hours it work for 5 minutes and dies again.
Does anyone know where the sensor (or maybe the sender?) is located.
I searched the forum and found an extensive thread for the ECU sender.
I understood it is feeding the computer only, not the dashboard gauge.
I need to replace/troubleshoot the one that feeds the gauge.
Thank you.
Old Dec 26, 2004 | 01:56 AM
Jestnomen's Avatar
6th Gear
Default RE: A6 temp Gauge intermittant
have the car scanned with a vag-com first off to see if there are any problems showing up.
Old Dec 31, 2004 | 01:50 PM
powerboat's Avatar
I scanned the car with VAG-COM.
No error codes at all.
Old Dec 31, 2004 | 09:27 PM
Jestnomen's Avatar
6th Gear
my guess would be the instrument cluster then. when the temp sensor goes bad, it throws a code.
Old Jan 10, 2005 | 10:15 AM
powerboat's Avatar
Hmm...
When using VAG-Com there was a feture to check instrument panel gauges. The Temp. gauge arrow moved smoothly from 0 to max and back.
I assume the temp gauge must be good....
Old Jun 10, 2005 | 02:54 PM
Nutt99A6's Avatar
Did you ever figure out what went wrong with the gauge my car is also showing cold did you just have a bad connection or was it grounding out Im having the same thing happen
Old Jun 10, 2005 | 11:29 PM
powerboat's Avatar
Yes, it is the Instrument Cluster. Needs replacement - the whole thing!
The gauge is OK.
badone
Oct 3, 2014 11:19 AM
zedea
Jan 18, 2013 03:11 PM
A4driver17
Jan 3, 2012 11:29 PM
Russell2686
Jul 8, 2009 11:55 AM
dsrtibb
Jul 24, 2007 08:00 PM
