Anyone put HID's in their A3?
Old Nov 7, 2006 | 08:21 PM
illwork4sumbread's Avatar
Default Anyone put HID's in their A3?
Hey all-
After looking around on the A4 forum a little bit, I noticed that maybe 15-25% of the members have an aftermarket HID kit in their car. When I bought my A3, I was on a budget and couldn't spring for the xenons. Has anyone here made the headlight upgrade? How hard was it? What product did you go with?
Thanks in advance.
Old Nov 12, 2006 | 08:50 PM
wchp's Avatar
Default RE: Anyone put HID's in their A3?
I am wondering as well.
OR
Has anyone tried just the 35 watt 5000K or 6000K bulbs and ballasts in the OEM lens assembly ?
Old Nov 13, 2006 | 05:41 AM
boywonder's Avatar
I don't know about the HID conversions - I think they're pretty expensive.
But here's another option I came across - A3 Projector Headlamps that are only $440.
http://www.ngpracing.com/Merchant2/m...audia3headlamp
Old Nov 13, 2006 | 07:50 AM
syndrome69's Avatar
I emailed a guy from ultrabrightlights.com to get advice on what type of lights to get for the A3, I'll let you know his responses.. He hooked up my friend who has an evo 9 and it looks as close to Xenon's as ive seen.
I too am looking for HID's, was a bit dissappointed with my A3 not having Xenons too, I asked if they could install it at Audi but they said its far too complicated because Xenon lights auto adjust as you go round corners.... so HIDs are the only real alternative i think.
Old Nov 13, 2006 | 08:11 AM
wchp's Avatar
ORIGINAL: syndrome69
Xenon and HID are the same thing High Intensity Discharge lamps contain Xenon Gas hence the interchangeability of names.
See this article: http://uk.cars.yahoo.com/24032006/45/ukiedata-0.html
A3 with Halogen rated 4 stars
A8 with Xenon projection rated 5 stars and #1 overall
also read this thread http://forums.vwvortex.com/zeropost?...how&id=2924140
Old Nov 13, 2006 | 08:38 AM
syndrome69's Avatar
Well what i meant is that there is a big difference between the Xenons you get from Audi as opposed to aftermarket bulbs.. and Audi told me it is too complex to fix their type of Xenons to cars (like my 2006 A3) that already have halogen bulbs
Old Nov 13, 2006 | 08:46 AM
wchp's Avatar
I have not found a HID lens and light kit yet. There is probably a fixed or self leveling kit somewhere out there without the adaptive/cornering feature but I have yet to fine it.
One would think a OEM HID lens assembly would work as long as you didn't care about the cornering system (installed as a straight ahead only system)
Are you doing this for performance (live/drive in very dark environments with long distance vision a plus) or just looks.
If you are looking for more light, you might try using some of the European Bulbs like the Phillips Vision Plus or GE Megalight Plus:
http://www.autolamps-online.com/halogen/index.htm
I have been using the Phillips Vision Plus in my Hella Projection lamps on my B5 Passat for years and love them. I don't give a crap about the HID look... I just want better light.
**** NOTE **** the pricing on auto-lamps online is in British Pounds.
Old Nov 13, 2006 | 08:52 AM
syndrome69's Avatar
speaking of aftermarket bulbs... will this void Audi's warranty?
Old Nov 13, 2006 | 08:59 AM
wchp's Avatar
If the bulbs were to blow up or the ballast catch on fire I would say yes. But as the replacement bulbs are 35w and generate less heat, as long as the wiring job was done well how would it?
It only "Voids" the warranty if the non factory part or its installation causes the problem. So if the wiring was set on the manifold and started a fire... that would void things. But if you install the lights and the radio stops working and there is no correlation then no.
Old Nov 13, 2006 | 09:05 AM
syndrome69's Avatar
so if i show up at the next service with new HIDs they wont say right we're cancelling your warranty then?
