98 Audi A4 2.8 doorlock problem...help
Old Jan 18, 2003 | 10:54 AM
Ed J's Avatar
Default 98 Audi A4 2.8 doorlock problem...help
What's up everyone...I just bought a used 98 A4 2.8. My problem is with the door locks. I'll give you a run down...
I was inside the car with my friend. I unlocked the doors with the door switch located at the driver's side, so my friend can buy something. I then lock the doors and waited for my friend. As he approached, I unlock the doors but he couldn't open the doors...I tried locking and unlocking with the switch again and still the doors would not open from the exterior.
However, I tried another test, I unlock the doors with the switch and closed the doors, if I didn't touch the lock and unlock switch, I no problems opening the door.
Sorry for the long note...is this a problem or is there something I can do???
Thanks...
Old Jan 18, 2003 | 12:53 PM
BoostedA4's Avatar
when u unlock the door, does the lock go up or just stay down? Myabe try unlocking the door with the key, and retry the powerlock after that.
Old Jan 18, 2003 | 05:10 PM
Ed J's Avatar
Yes, that's correct. When I tried to unlock the door with the switch the lock just stays down. Another info...when I do use the remote, it works fine. It locks and unlocks, with the remote that is...
Old Jan 18, 2003 | 07:02 PM
BoostedA4's Avatar
Just a guess, but it might be an electrical problem for that door in the connection with the power doorlock switch on the drivers side. I don't know if there is a fuse for this, but if there is you might want to try and replace it. Its probably not just a fuse, but you never know.</P>
Old Jan 18, 2003 | 07:07 PM
BoostedA4's Avatar
So does just the front passenger side door not lock or unlock, or is it all the doors. Because I checked and there is a fuse for the central locking system, but if its just that one door, then I highly doubt its a fuse.
Old Jan 18, 2003 | 08:22 PM
Firestarter1984's Avatar
sounds like its one of Audi's common electrical system problems, i have had the same thing but it as a chevy lumina and it was a bad contact inside the door
Old Jan 18, 2003 | 08:35 PM
Ed J's Avatar
It's all the doors that does not unlock when I press onto the switch. But it does lock all the doors. Also, as I mention before, when I use the remote, the door locks and unlocks.
sheafiw41
Jul 16, 2013 03:26 PM
pierlucke
Sep 2, 2012 09:03 AM
COH
Nov 19, 2010 03:35 AM
mrelmo
Apr 16, 2009 08:30 PM
Ed J
Jan 20, 2003 01:07 AM
