[Deleted]
Old Aug 20, 2003 | 10:23 AM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Oct 2, 2003 | 07:08 PM
Default [Deleted]
[Deleted by Admins]
Old Oct 31, 2003 | 10:28 PM
Default [Deleted]
[Deleted by Admins]
Old Oct 31, 2003 | 10:57 PM
Default [Deleted]
[Deleted by Admins]
Old Feb 27, 2004 | 08:33 PM
BiTurboMan's Avatar
Default ABS brake noise???
check the wheel sensors.....It might be the ABS sensors are dirty... I have heard of this problem before and it is usually due to the fact that one of the sensors is dirty / blocked and the other one fine.... hence thebraking effect...</P>
remove, clean and re-install the sensors / connectors..</P>
Old Jan 14, 2006 | 06:29 PM
thekennells's Avatar
Default RE: ABS brake noise???
I just noticed this noise on my 1998 A4 Avant yesterday. Can anyone confirm that it is the sensors? If it is the sensors, where exactly are they located? Any help would be greatly appreciated.
Thanks!
Old Jan 14, 2006 | 09:43 PM
dan908's Avatar
Yeah it is probably loosely replaced or dirty sensors.
Does it feel like a shudder or viibration in the pedal. Kind of sounds like farting?
In the front of the rear rotors and behind the front rotors, there is a wire coming off the ABS computer to a head (but not a brake hose (know the difference)) It goes into a head (black plastic) with a magnetic cylinder maybe 5/8in diameter on the rotor end. On all you guys with the older 98 and 97s it(the head and magnet) just slides in and out. If it was never cleaned it will be a little work. Get something with a soft grip head and get a good grip on the cap and twist it loose (like battery cable removal- no prying) Well you should start with just using your fingers, but if they dont work, I used vice grips on a shop rag. Audi has a tool, but they could not get mine. Anyway, your sensors may set off the check engine or ABS lights if they are dirty and will eventually burn up (160 parts/ wheel). Oh yeah after you get it out, wipe off the crap, wipe down with a little oil (to make it easier to pull the next time). And uh, on the newer ones, I hear the cap is a locking ring kind of thing so twist first before pulling. And uh don't break one, it could be bad.
Deleted User
Feb 27, 2004 08:42 PM
Deleted User
Jan 27, 2004 12:58 AM
Deleted User
Oct 23, 2003 03:37 PM
Deleted User
Sep 22, 2003 09:08 AM
Deleted User
Sep 21, 2003 02:30 PM
