ECS Coilover kit...
Old Aug 9, 2007 | 07:44 PM
Avant1.8t's Avatar
Default ECS Coilover kit...
anyone tried it? im very tempted. right now i have koni shocks with ebiach springs, i assume it would work? im just a little confused one what the rest against, like when you tight ur adjustments whats the coil over kit held on by?
Old Aug 11, 2007 | 01:07 AM
Borden's Avatar
Default RE: ECS Coilover kit...
From reading the ECS site it says that only aftermarket shocks and springs work so you with aftermarket springs and shocks should work. It also appears to be held on by a set screw of some kind that just puts pressure on the shock
A4Johnson86
Mar 30, 2012 07:06 PM
kelseysautobody
Feb 19, 2009 08:35 PM
reed1099
B7 Models
Jan 29, 2009 07:07 PM
sandman
Oct 24, 2005 04:47 AM
adiktedkidz
Nov 19, 2003 02:44 AM
