water pooling under brake booster - from cowl
Old Feb 1, 2008 | 02:34 PM
grossgary's Avatar
Default water pooling under brake booster - from cowl
1997 Audi A4 Quattro - hello first post. This is a friends car and I try to help them out.
There is a hole in the cowl, around the passengers side close to the brake booster (sp?) that water drips through when it rains and the water pools under the brake booster. I'm thinking this is one of two things:
That hole shouldn't be there.
There should be some kind of collector under that hole to drain the water elsewhere.
Or I need to teach the brake booster to swim and hold it's breath!
Water also drips from the middle clip holding both halves of the cowl plastic in place...should i use sealant at the juncture of the two halves to prevent that?
Thanks,
Gary
Old Feb 1, 2008 | 02:38 PM
techbod's Avatar
Default RE: water pooling under brake booster - from cowl
all items going into the cab have a seal so if there is a leak just seal it
Old Feb 1, 2008 | 02:48 PM
dankhound's Avatar
The plenum area with the battery and the brake booster has drains so water doesnt pool there. The drains are probably just plugged. It may be under the battery on that car.
Old Feb 1, 2008 | 03:23 PM
grossgary's Avatar
so this water IS supposed to drip into the engine bay (between the engine and firewall/windshield), but it's supposed to be able to drain from that area?
thanks guys, you're quick!
Old Feb 1, 2008 | 03:30 PM
techbod's Avatar
ORIGINAL: grossgary
it will if its not full of leaves
mel23816
Apr 7, 2014 04:09 PM
Shun
Mar 3, 2009 02:18 AM
rh1231979
May 28, 2008 12:53 AM
bolob5
Apr 1, 2008 06:18 PM
lavadrifter
May 9, 2007 10:40 PM
