Does a Bad O2 /EGT cause RPM not to go over 4000
Old Mar 2, 2008 | 03:41 AM
jasmix's Avatar
Default Does a Bad O2 /EGT cause RPM not to go over 4000
1999 A4 1.8t Auto - Does a Bad O2 /EGT cause RPM not to go over 4000?
stupid question but does a 1.8T have EGT where is it located? diagram?
I read EGT can leave the Wastegate open causing no boost after certain RPM's
I have replaced Coils/ Plugs / ICM/ MAF/ checked for leaks ...also No codes
Old Mar 2, 2008 | 06:28 AM
hiwords's Avatar
Default RE: Does a Bad O2 /EGT cause RPM not to go over 4000
no codes or jsut no cel? you might have a code stored. it sort of sounds like you're inlimp mode.
Old Mar 2, 2008 | 02:40 PM
jasmix's Avatar
no codes...no cel.. checked them again?? how do you reset limp mode
Old Mar 2, 2008 | 02:43 PM
jasmix's Avatar
I did reset the ECU..actually put another one in...but still the same
Old Mar 2, 2008 | 02:52 PM
auditech79's Avatar
Only the 2.7T has EGT sensors, you can re-set limp mode just be erasing the faults. But something is causing you to go into limp mode.
Is this an automatic?
Old Mar 2, 2008 | 02:55 PM
jasmix's Avatar
yes Auto... but its changing through all gears... does a bad O2 cause this ?
Old Mar 2, 2008 | 03:00 PM
auditech79's Avatar
Still check the fault memory in the gearbox and brake electronics. A faulty brake light switch can cause this, so could a faulty TR (transmission range) switch.
A bad O2 sensor would most likely throw a fault code.
Old Mar 2, 2008 | 03:05 PM
jasmix's Avatar
I dont have VAG can I try it with something else...? take the battery off? im sure thre are no brake light off
Old Mar 2, 2008 | 03:08 PM
jasmix's Avatar
where is transmission range switch? also the location of transmission ecu
Old Mar 2, 2008 | 03:15 PM
auditech79's Avatar
You need a VAG COM to test these systems.
The TR switch is the entire circuit board under the shifter assembly. The brake light switch does a lot more than just turn on the brake lights.
