Climate Control Removal 01 A4
Old Mar 23, 2008 | 05:27 PM
grkmchn's Avatar
Default Climate Control Removal 01 A4
Trying to remove the climate control in an 01 A4. I have the radio out already. Also trying to remove the wood trim that surrounds the fog light button and cupholder. Thanks.
Old Apr 29, 2009 | 09:19 PM
Polisan's Avatar
Default climate control
The top trim piece just pulls straight off and I am also trying to figure out how to pull this climate control unit out. Unscrewed every screw i could find and the thing still doesn't budge
Old Apr 30, 2009 | 09:05 AM
vgo's Avatar
vgo
i think you'd have to remove the whole centre console including the bracket itself before you could remove the climate control.
can someone else shed some light here?
Old May 1, 2009 | 05:47 PM
shortyxc's Avatar
I took out the whole console to get it out. Disconnect the wires in the back and pull it straight out.
Old May 1, 2009 | 10:39 PM
Polisan's Avatar
By whole console do you mean everything? The Haynes manual didn't have a very good description in it for this so I was leary about pulling the trim from the top wood surround. I did get it to move a bit but it seems to be attached to the trim from behind. I have to take the climate controller apart to clean out the coffee if i ever want to use my defrost or turn it off of auto 70 degrees.
Old May 2, 2009 | 01:27 AM
Tweaked's Avatar
This will break. The clips holding are mostly a one-time deal and the wood is extremely easy to crack. Try using a plastic spatula, but be prepared to replace this trim. It sucks.
Old May 7, 2009 | 10:34 PM
Polisan's Avatar
So I go today and try to work on getting this climate controller out because now the thing won't stay on. It only works if I press in the slow fan toggle, up and down temps at the same time and continue to hold a button. Anyways, i started to insert the radio tools and lo-and-behold, one of the tools slides right past where it should engage. I worked at it for a while with no results. Anyone know how to get the radio out when the tools won't work or know of how to "reset" the climate controller?
Old May 8, 2009 | 01:10 AM
jmgrande's Avatar
I'm trying to get mine out also. The previous owner must have spilled something on it, I need to get my mine out and clean it.
Old Oct 19, 2009 | 05:59 PM
[KSU]KEvin's Avatar
BUMP!
just bought a new climate control because i was retarded and destroyed my old one. Regardless! anyone who could direct me as to how to remove the climate control in the easiest way possible will save me. its gettin cold, i need defrost.
kevin
Old Oct 19, 2009 | 07:20 PM
TeeterTawter's Avatar
^^^just hold your breath lol windows won't fog.
http://www.audiworld.com/tech/elec153.shtml for a 96-97
http://www.audiworld.com/tech/elec152.shtml
