Cats! Rawr. Running without!?
Old Apr 21, 2008 | 05:03 PM
carlv's Avatar
Default Cats! Rawr. Running without!?
Ok so umm... I'm getting a lot of noise from what I believe are the cats.. or one of them anyways. The engine is kind of suffocating i think or w/e because of it.. if i disconnect the pipe from above one of the cats and start it up.. will it run stronger if the cat is the issue ( i know it will be a bit loud.. but will it run "clean" with one disconnected or does it need the system inplace to know if it's working correctly?
Old Apr 22, 2008 | 12:18 AM
auditech79's Avatar
Default RE: Cats! Rawr. Running without!?
What are the codes? Do you have a check engine light? If the cat converter is clogged it would have a severe lack of power.
Old Apr 22, 2008 | 10:36 AM
blue2.8a4's Avatar
Recently i bottomed out and cracked the header pipes right before the cats on both sides - when i started it up it was so freaking loud the whole car was vibrating. If you disconnected it somehow, I think you would know.
Old Apr 23, 2008 | 02:25 AM
david9999's Avatar
If you are getting lots of noise, it probably isn't the cats, but the flex pipe.
Put the car up on stands and check it out. Do not use a jack to hold your car up when you are underneath.
wmdunk
Oct 22, 2010 10:02 AM
travish325
Sep 25, 2010 05:37 PM
derek072887
Jun 12, 2008 12:07 PM
TKneedsS4
Nov 5, 2007 02:35 PM
