Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Arnott's New Front Air Struts for '06-'11 Audi Feature Custom-Tuned Shock
Old 03-27-2017, 08:57 AM
arnottdoug's Avatar
Arnott Air Suspension
Default Arnott's New Front Air Struts for '06-'11 Audi Feature Custom-Tuned Shock
AS-2816 and AS-2817 are new, Arnott engineered, aftermarket air suspension struts for the Front Right side and Front Left Side of the 2006 to 2011 Audi A6, Avant, allroad Quattro, and S6 (C6 Chassis; TYP 4F).
These new -- not remanufactured -- assemblies replace OE Part Numbers:
4F0 616 040 S and 4F0 616 040 AA (Right)
4F0 616 039 S and 4F0 616 039 AA (Left).
AS-2816 and AS-2817 replace the OE strut and often problematic adaptive damping found on remanufactured units and feature a new custom-tuned shock absorber calibrated to provide an excellent ride and outstanding performance.
The Arnott Air Struts include a new air bladder from ContiTech protected by an aluminum can along with a CNC-machined top mount made from aircraft-quality aluminum. These new Air Struts are assembled in the USA with Arnott's long-lasting seals, O-rings, bumpstop, heavy-duty crimping rings, new air fitting and connector valve along with a dust boot to protect the strut.
AS-2816 and AS-2817 retail for $699 each and are backed by Arnott's renowned Limite Lifetime Warranty. A limited time $75 used strut core Return Rebate applies to each new Arnott Air Strut.
Features:
* New Custom-Valved Shock Absorber
* Multi-Ply ContiTech Air Spring Bladder
* Pre-Assembled for Easy Installation
* Includes Detailed Installation Manual
* Designed & Assembled in the USA
matthew.riley0
01-04-2014 07:09 PM
cdtran6273
10-22-2013 11:35 AM
trshman6
08-17-2013 12:57 PM
mightyb28
07-03-2012 05:30 PM
2009A42.0t
B8 Models
04-27-2009 10:36 PM
Quick Reply: Arnott's New Front Air Struts for '06-'11 Audi Feature Custom-Tuned Shock
