tt 1.8 crankseal installation help
Old Sep 4, 2008 | 03:51 PM
gsxr1000's Avatar
Default tt 1.8 crankseal installation help
This weekend im doing my timing belt and I have a small oil leak on the right side, probably crankseal. So I got a new crank seal with my "plus extra" kit from mjm autohaus. Anything to the crankseal? I cant find info. Are they hard to get out? Is there room to get the pully off with a puller or is it to tight? Thanks
Art
2000 tt quattro 1.8 5spd
Old Sep 4, 2008 | 05:43 PM
auditech79's Avatar
Extremely hard to pull out, and i really wouldn't mess with it un-less you have the exact special tool from pulling it out and if its leaking something fierce. Luckily enough 98% of the time that seal never leaks, more than likely its just a VC (valve cover) leak. Is there oil coming from the front side of the engine where the timing belt is?
Old Sep 4, 2008 | 07:30 PM
gsxr1000's Avatar
ah ok, ill see if i can get the tool if it is leaking, I should be able to see better where the leak is from when i get it all torn aparn. The oil is on the right side where the timing belt is but doesnt apear to be any on the front. Thanks for the input! I definatly wont mess with it if it isn't leaking.
Old Sep 4, 2008 | 07:41 PM
auditech79's Avatar
If you're leaking from the back of the motor then i would also suspect the cam adjuster seal, it looks like a little half moon seal thats under the tensioner. Its a little harder to replace than the VC gasket but if you're gonna change the VC gasket you might as well change the cam adjuster seal too. That seal is only like $15.
Old Sep 6, 2008 | 07:20 PM
gsxr1000's Avatar
well I took enough stuff off including the timing belt cover thing to see the leak is not coming from anywhere near the valve cover gasket or the cam so time to start tearing... fun fun
Old Sep 7, 2008 | 12:31 PM
tytiiiore's Avatar
Banned
Angry The Reason of Being Late
Bump! thx !   Teacher: Johnny, why are you late for school every morning?  Johnny: Every time I come to the corner, a guidepost says, 'School -- Go Slow'.Welcome to our website for you World of Warcraft Gold,Wow Gold,Cheap World of Warcraft Gold,buy cheap wow Power Leveling,real wow gold,sell wow gold, ... Supply Cheap WoW Gold to our loyal customers. Buy WoW Gold,cheap aoc gold, now, we have available stock of aoc power leveling,on most of the servers. We can provide really cheap World of warcraft Power Leveling. Enjoy a new life, We are a world class wow Power Leveling store online !
Old Sep 7, 2008 | 02:06 PM
auditech79's Avatar
tytiiore: IF you post SPAM like that again i will erase all your posts and delete your account.
Old Sep 9, 2008 | 10:42 AM
gsxr1000's Avatar
Well it wasn't either of the seals we guessed, but I really appreachiate your input. It appears my cam seal wasnt set right from factory? I dont know, I took some pics of it. It just sucks while taking the bolt out it turned it slightly back from top dead center so now I gotta screw with that but could be worse I guess.
Anyhow not the one with the cam gear, but to the right with the cover with the connection on appeared to have some oil dripping out so I took that off to find a few peices of broken plastic with the seal partway out, I really don't know what happened, but I guess to fix it, 2 self tapping screws to pull it out? Then put the new one in and tap it in w/ a socket?
Old Sep 9, 2008 | 11:03 AM
gsxr1000's Avatar
Old Sep 9, 2008 | 01:11 PM
gsxr1000's Avatar
disregard, i just popped it out from the point it was sticking out, then used a 34mm socket with a headbolt going through it to draw it in snug after lubing it with oil
Brass tax
Jul 3, 2013 11:38 PM
Bosno
Apr 4, 2009 02:17 PM
Leifer
Jul 22, 2008 09:11 PM
Keyboard Ninja
May 26, 2007 05:11 PM
dblock110
Feb 25, 2007 02:38 PM
