Help!!!!
Old Oct 9, 2008 | 09:04 PM
Bad Justin's Avatar
Default Help!!!!
please read my posts on AW in regards to my axle problem today..... if anyone has a pic of what a MANUAL axle shaft should look like I'd appreciate it ... thanks guys ...
http://forums.audiworld.com/a6100/msgs/94154.phtml
Old Oct 10, 2008 | 01:28 PM
nemohm's Avatar
My guess is the difference could be in the length ?
It is not clear what exactly happened?
Some details could be useful..
Old Oct 11, 2008 | 10:51 AM
Bad Justin's Avatar
NAPA boxed the axles wrong ....... they boxed an automatic axle in a manual box. Difference is the way the bolt into the tranny. Auto/Tiptronics hace a closed out cv joint like the one in the pic I posted on AW the manuals have an open end which needs to be packed with grease as seen here
http://www.empius.com/2008_driveaxle...s/80-9049.html
just an FYI in case anyone else was wondering
Old Oct 12, 2008 | 11:09 AM
a6hcw's Avatar
The front inner CV joint of the automatic has a tripoid joint, instead of the one used on manual transmissions. The CV boots are different. There are pictures of these parts at www.AudiCarParts.com . The inner manual CV joint requires a gasket at the flange. The front inner tripoid CV joint has no gasket.
