-   Computer & Fuel Systems (https://www.audiforums.com/forum/computer-fuel-systems-27/)
-   -   What did I screw up? (https://www.audiforums.com/forum/computer-fuel-systems-27/what-did-i-screw-up-16679/)
A4orced Sep 19, 2005 10:14 PM
I was checking the air filter the other day to see what the condition was, looked good so I put it back in. About 3 hrs later the CEL came on, shortly after that I noticed alot of bucking and hesitation... and it's getting worse, it will barely idle and its died 3 times. The CEL is reading as a MAS problem, low voltage I think. I checked for loose wires or if I unplugged something--nothing that I can see. Any Ideas, I doubt the MAS is so sensative it will die after having a filter change.
A4orced Sep 20, 2005 10:18 PM
RE: What did I screw up?
nothing, not even a guess?
mastvadz71 Dec 18, 2005 05:08 PM
did you remove the mass air by any chance while cheking the filter
techbod Feb 1, 2006 04:26 PM
did you loosen any pipes/unplug the maf and switch the ignition on, ensure all pipes are tight
avanttripleloop Feb 11, 2006 03:06 PM
old post but,with the car running tap on your purge valve,it sits on the air housing,it'll tell ya right then if it's bad,same happened with mine.
