Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
What did I screw up?
Old Sep 19, 2005 | 10:14 PM
A4orced's Avatar
Default What did I screw up?
I was checking the air filter the other day to see what the condition was, looked good so I put it back in. About 3 hrs later the CEL came on, shortly after that I noticed alot of bucking and hesitation... and it's getting worse, it will barely idle and its died 3 times. The CEL is reading as a MAS problem, low voltage I think. I checked for loose wires or if I unplugged something--nothing that I can see. Any Ideas, I doubt the MAS is so sensative it will die after having a filter change.
Old Sep 20, 2005 | 10:18 PM
A4orced's Avatar
Default RE: What did I screw up?
nothing, not even a guess?
Old Dec 18, 2005 | 05:08 PM
mastvadz71's Avatar
Member
did you remove the mass air by any chance while cheking the filter
Old Feb 1, 2006 | 04:26 PM
techbod's Avatar
did you loosen any pipes/unplug the maf and switch the ignition on, ensure all pipes are tight
Old Feb 11, 2006 | 03:06 PM
avanttripleloop's Avatar
old post but,with the car running tap on your purge valve,it sits on the air housing,it'll tell ya right then if it's bad,same happened with mine.
Amybc96
B7 Models
Jun 29, 2015 07:37 PM
mjmssline
B7 Models
May 30, 2010 12:29 PM
audia6s
Apr 16, 2008 05:33 PM
DiscoStu9
Sep 24, 2007 04:54 PM
Haligan4129
May 2, 2007 10:16 PM
