how much does it help
does a suspension drop really help my performence or is it mostly to look cool;)
RE: how much does it help
yes it does. and No.
if you drop the suspension to deep, you gona hurt the performence. to get real performence. a little drop required. I usually count by the amout that the CV is tealted. I think real performance is when CV is 0 degrees. of the stick is 90 deg to the wheel. becouse you load the car time to time, the OEM designed to be a little higher thats the full performence. So you will need to calculate all the variables to get it righgt. |
in that case illl leave mine stock it costs alot of $$$$$$ plus i work on road that is half dirt and ive seen what happens when you bottom out a car. ive also been in a car when you go too fast over a railroad Xing but thats a different story
| All times are GMT -4. The time now is 02:14 AM. |
