Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
how much does it help
Old Apr 28, 2006 | 12:30 AM
qUattro_tYrant's Avatar
Default how much does it help
does a suspension drop really help my performence or is it mostly to look cool
Old Apr 28, 2006 | 06:34 PM
kakarot's Avatar
Default RE: how much does it help
yes it does. and No.
if you drop the suspension to deep, you gona hurt the performence.
to get real performence. a little drop required. I usually count by the amout that the CV is tealted. I think real performance is when CV is 0 degrees. of the stick is 90 deg to the wheel.
becouse you load the car time to time, the OEM designed to be a little higher thats the full performence. So you will need to calculate all the variables to get it righgt.
Old Apr 28, 2006 | 09:48 PM
in that case illl leave mine stock it costs alot of $$$$$$ plus i work on road that is half dirt and ive seen what happens when you bottom out a car. ive also been in a car when you go too fast over a railroad Xing but thats a different story
