-   Computer & Fuel Systems (https://www.audiforums.com/forum/computer-fuel-systems-27/)
-   -   Added fueling with K03s? (https://www.audiforums.com/forum/computer-fuel-systems-27/added-fueling-k03s-34218/)
ChiTowNS401 Jun 15, 2006 05:37 PM
Question for the Gurus. If I put in lets say the green top injectors, 5 bar FPR, MBR, and anything else I would need, could I get more power out of the K03s?
ChiTowNS401 Jun 19, 2006 01:50 PM
RE: Added fueling with K03s?
[sm=feedback.gif]
techbod Jun 19, 2006 02:26 PM
well of course you could as long as the fuel pump/filter can deliver
Iceman9100 Jun 19, 2006 03:55 PM
I wish I could tell you becaus eI have no idea.[X(]
techbod Jun 19, 2006 04:07 PM
well I could, you installed a FPR but didn't consider the fuel pump pressure delivery which is 6 bar max but will never reach that because of the demands you put on your engine so when you boot the peddle you go beyond the limits and the system fails, what did you expect??;)
ChiTowNS401 Jun 19, 2006 05:22 PM
Thing is, I don't see the fuel pump/filter in any of the stage3 kits, although I believe a Fuel Pressure Regulator is as well as injectors. So why would adding fuel to K03s be any different? So Could I run stage 3 software on K03s if I upgraded the fueling is my question.
And BTW, I didn't install anything yet. This was just an idea to see if I could...;)
janin Jul 25, 2006 06:14 AM
ORIGINAL: ChiTowNS401
why would you wan't to though? one of the main points of altered fuel and ignition maps via a chipped ecu is to run a different/more efficient turbo. to put match a nice-to-nasty map on a small turbo would be a mute point. however to answer your question yeah i guess you could run stg 3 software on KO3, (i've seen worse in different car circles) but then to take advantage of said software you might wind up cranking up the boost on a KO3 past its efficiency realm.
mike (as usual)
