Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Added fueling with K03s?
Old Jun 15, 2006 | 05:37 PM
ChiTowNS401's Avatar
Default Added fueling with K03s?
Question for the Gurus. If I put in lets say the green top injectors, 5 bar FPR, MBR, and anything else I would need, could I get more power out of the K03s?
Old Jun 19, 2006 | 01:50 PM
Default RE: Added fueling with K03s?
[sm=feedback.gif]
Old Jun 19, 2006 | 02:26 PM
techbod's Avatar
well of course you could as long as the fuel pump/filter can deliver
Old Jun 19, 2006 | 03:55 PM
Iceman9100's Avatar
I wish I could tell you becaus eI have no idea.[X(]
Old Jun 19, 2006 | 04:07 PM
techbod's Avatar
well I could, you installed a FPR but didn't consider the fuel pump pressure delivery which is 6 bar max but will never reach that because of the demands you put on your engine so when you boot the peddle you go beyond the limits and the system fails, what did you expect??
Old Jun 19, 2006 | 05:22 PM
Thing is, I don't see the fuel pump/filter in any of the stage3 kits, although I believe a Fuel Pressure Regulator is as well as injectors. So why would adding fuel to K03s be any different? So Could I run stage 3 software on K03s if I upgraded the fueling is my question.
And BTW, I didn't install anything yet. This was just an idea to see if I could...
Old Jul 25, 2006 | 06:14 AM
janin's Avatar
ORIGINAL: ChiTowNS401
why would you wan't to though? one of the main points of altered fuel and ignition maps via a chipped ecu is to run a different/more efficient turbo. to put match a nice-to-nasty map on a small turbo would be a mute point. however to answer your question yeah i guess you could run stg 3 software on KO3, (i've seen worse in different car circles) but then to take advantage of said software you might wind up cranking up the boost on a KO3 past its efficiency realm.
mike (as usual)
brolo747
Oct 25, 2010 03:41 PM
chosos
Jan 27, 2009 03:11 PM
$4Jordan
Nov 19, 2008 12:10 AM
Cbass
Nov 16, 2008 06:39 PM
mr.cAp
Feb 9, 2008 12:59 AM
