Speed limit
[:@]I have just recently bought an Audi A6 here in the U.S. When I took it for the first longer dinstance I came to realize that I had a speed limiter in it.
My question is do I have to replace the chip or is there a less expensive version to overwrite this limiter?? |
RE: Speed limit
you didnt mention what year, mine is a 99, and as I recall it, there is a jumper wire off the ecu that gets cut
RE: Speed limit
yes mine is a 99 also, can you explain more exact how to do this.
I'd appreciate |
RE: Speed limit
what is the limiter set at BTW which engine is this in your A6
RE: Speed limit
I have just the basic 2.8 quatro. The car begins to stutter at about 95 - 100 miles an hour. I know it can go more because back in germany I have driven one an it went way above 100 miles an hour
RE: Speed limit
If it is cutting out at that speed it is not the speed limiter it comes in around 130mph
RE: Speed limit
I have a 99 A6 and I recall my manual talking about setting the speed governor. It was in the section dealing with snow tires as they are not rated for high speed.
RE: Speed limit
Time to get out the vag.com or take it to the dealer see if they can remove that but you say it just shutters like it will not go any more or the car is shaking ?
| All times are GMT -4. The time now is 11:08 PM. |
