-   -   Dead pixels at multifunction display. (https://www.audiforums.com/forum/audi-a6-9/dead-pixels-multifunction-display-61890/)
vrso2 Apr 27, 2007 11:06 AM
Hmm, i got missing some "lines" at my multifunction display. Is any way to do repair?
slee22 Apr 27, 2007 12:28 PM
RE: Dead pixels at multifunction display.
You have to replace the enitre instrument cluster. Most of the time you can find a used one, which is quite a bit cheaper. Check www.shokan.com and http://www.4usedaudiparts.com/
SSn Apr 27, 2007 04:50 PM
No offence to anyone but I'll try to take the old one out first and take a look at it before replacing the whole thing.
Don't know how this lcd is made, but I fixed the same problem in a Sony CD player once. That LCd had many contacts soldered to the main board in a faceplate and with time some got loose and broke off. So I resolderet every single contact and it is as new again.
I understand this lcd is more complicated, but, looking inside will not hurt.
joblessone Apr 27, 2007 09:22 PM
let us know how it goes when you look into it..... Of course I have the same issue....
vrso2 Apr 27, 2007 10:00 PM
hmm, thats the disease of all audi. :(
mcicoria Apr 27, 2007 10:21 PM
Same thing is happening to my 99 A6. For those of you with more experience with this, how bad does it get? I am only missing a few "lines" right now as well.......
Boston Driver Apr 27, 2007 11:17 PM
This is a known issue with the A6, and you cannot replace the display. The real issue is the micro-thin ribbon wire that connects the circuit board to the instrument display. When it gets hot out, it will get worse! The ONLY way to fix this is to replace the cluster. Sorry, many have tried and failed.
If you have a pre-2001 (i.e. no immobilizer) it is a simple process. You buy a remanufactured unit from the dealer, which once installed can be recoded (with a VAG COM)to the correct mileage on the odometer. You then return the damaged cluster to the dealer, and they give you back a core charge/deposit. Net out is about $400 I think for this swap.
If you have a 2001 or alter with the immobilizer, unless you have the Secret Key Code (SKC), you will need the dealer's help for this replacement. No way around it.
vrso2 Apr 28, 2007 11:09 AM
Thx, now i'm 100% sure, ill drive with missing pixels for next two years. ;) (then i think ibuy A8).
andrieso Apr 28, 2007 01:58 PM
Interesting thread about the multifunction display. I bought my 2000A6 with the same problem and the dealer has offered to replace the particular board. It appears if the cluster is opened and the defective board is simply pulled off and replaced with the new component. I guess in South Africa things could be different but the Audi dealer did not indicate anything about replacing the entire cluster.
audiguy Apr 28, 2007 02:05 PM
The issue is the micro-thin ribbon wire that connects the circuit board to the instrument cluster, and you cannot replace the display. You can contact these people http://www.aaellc.com/ they transfer the data from your old cluster to your new one.
best of luck.
