Engine Check Light On - P1128 and P1130
Hi All, I bought my first Audi, its a 2000 4.2 A6. After I had driven the car a 1000 miles the check Engine Light turned on. I got it diagnosed and found that the the Error Codes are : P1128 Heated Oxygen Sensor Signals reversed. P1130 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1. My question is what is the cause of these codes and how can I fix them. Also is this something which requires immediate attention? And any rought estimate as to how much it will cost to fix these?:eek: Any help will be appritiated. -Thanks |
RE: Engine Check Light On - P1128 and P1130
Hey its your o2 sensors so you need to get them replaced and the second one is there is a block in the exhaust for some reason so get the new o2 sensor in there and see how that turns out good luck
any updates on this? I had this come up as well as cylinder misfires:
17536 - Fuel Trim; Bank 1 (Mult): System too Lean P1128 - 35-00 - - 17538 - Fuel Trim; Bank 2 (Mult): System too Lean P1130 - 35-00 - - 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-00 - - 16685 - Cylinder 1: Misfire Detected P0301 - 35-00 - - 16687 - Cylinder 3: Misfire Detected P0303 - 35-00 - - 16686 - Cylinder 2: Misfire Detected P0302 - 35-00 - - |
| All times are GMT -4. The time now is 02:38 AM. |
