-   -   Oil Pan (https://www.audiforums.com/forum/general-tech-50/oil-pan-82465/)
LeAudi19 Nov 22, 2007 08:28 PM
Oil Pan
Well, while i had my car towed.......... the stupid towing company took my car. They did NOT take it with a FLAT BED.
As a result they puncured my Oil pan
im trying to find the oil pan but i cant seem to find one
My Car as it says is a ......... 2001 Audi A6 2.8 L quattro and its a 5V(thats what it says in the engine cover, because most of the things i found were a 30V)
Can anyone please help me, i havent driven my car at all :(
dankhound Nov 22, 2007 10:50 PM
RE: Oil Pan
5V X 6 cylinders = 30V
You have a 30V. The covers just tell you how many valves per cylinder.
LeAudi19 Nov 23, 2007 12:22 AM
RE: Oil Pan
thanks i feellike a nooblol
which i still am
SAudi Nov 23, 2007 10:42 AM
RE: Oil Pan
so how did they exactly puncture the oil pan.
LeAudi19 Nov 23, 2007 11:44 PM
RE: Oil Pan
Well as i mentioned, all audis have to be towed on a flat bed.
the towing company just wanted to take my car and were careless, they towed it with the one that lifts both front wheels . While the things were going inside, they have to lock up- and close to the wheel, i guess while it did that it put pressure on the oil pan. then When i went to pick it up because i had to call another towing company to take it out , they brought a flat bed and I asked him about it. Whenhe responded, he saidit is like 90 percent that it was the first towing company foult for puncturing the pan.
ill post pics so you can see what kind of hole they made
cred05 Dec 6, 2007 01:29 PM
RE: Oil Pan
the fact that its a quattro means it needs a flat bed...if that idiot actually started to tow your car there would have been all kinds of problems
beefski Dec 6, 2007 02:08 PM
RE: Oil Pan
try shokan.com for the part. it should be the towing co.'s responsibility to repair the car, the damaged it by being careless. towing an awd car by the front wheels. you better make sure nothing else is f'ed up!
ouTTie914 Dec 6, 2007 05:25 PM
RE: Oil Pan
Part number for lower oil slump with opening for oil level sensor: 078103604AA
You can get it from AF's sponsor www.germanpartsonline.com. Cost about $125, you may need a new oil pan gasket as well.
Check out the damage before you order parts! You should also have your quattro checked out for damage.
Depending on how far they towed your car; it could be damaged as well! Worth looking into if you ask me...
SAudi Dec 7, 2007 07:05 PM
RE: Oil Pan
try FCP groton on ebay, i know i know ebay but i can vouch for them they come with a 12 month warranty and provide good parts, i actually just bought an lower oil pan for my car, for $65 and $25 oil pan gasket from NAPA.
http://cgi.ebay.com/ebaymotors/New-V...spagenameZWDVW
