Oil Pan
Old Nov 22, 2007 | 08:28 PM
LeAudi19's Avatar
Default Oil Pan
Well, while i had my car towed.......... the stupid towing company took my car. They did NOT take it with a FLAT BED.
As a result they puncured my Oil pan
im trying to find the oil pan but i cant seem to find one
My Car as it says is a ......... 2001 Audi A6 2.8 L quattro and its a 5V(thats what it says in the engine cover, because most of the things i found were a 30V)
Can anyone please help me, i havent driven my car at all
Old Nov 22, 2007 | 10:50 PM
dankhound's Avatar
Default RE: Oil Pan
5V X 6 cylinders = 30V
You have a 30V. The covers just tell you how many valves per cylinder.
Old Nov 23, 2007 | 12:22 AM
LeAudi19's Avatar
Default RE: Oil Pan
thanks i feellike a nooblol
which i still am
Old Nov 23, 2007 | 10:42 AM
SAudi's Avatar
Default RE: Oil Pan
so how did they exactly puncture the oil pan.
Old Nov 23, 2007 | 11:44 PM
LeAudi19's Avatar
Default RE: Oil Pan
Well as i mentioned, all audis have to be towed on a flat bed.
the towing company just wanted to take my car and were careless, they towed it with the one that lifts both front wheels . While the things were going inside, they have to lock up- and close to the wheel, i guess while it did that it put pressure on the oil pan. then When i went to pick it up because i had to call another towing company to take it out , they brought a flat bed and I asked him about it. Whenhe responded, he saidit is like 90 percent that it was the first towing company foult for puncturing the pan.
ill post pics so you can see what kind of hole they made
Old Dec 6, 2007 | 01:29 PM
cred05's Avatar
Default RE: Oil Pan
the fact that its a quattro means it needs a flat bed...if that idiot actually started to tow your car there would have been all kinds of problems
Old Dec 6, 2007 | 02:08 PM
beefski's Avatar
Default RE: Oil Pan
try shokan.com for the part. it should be the towing co.'s responsibility to repair the car, the damaged it by being careless. towing an awd car by the front wheels. you better make sure nothing else is f'ed up!
Old Dec 6, 2007 | 05:25 PM
ouTTie914's Avatar
Default RE: Oil Pan
Part number for lower oil slump with opening for oil level sensor: 078103604AA
You can get it from AF's sponsor www.germanpartsonline.com. Cost about $125, you may need a new oil pan gasket as well.
Check out the damage before you order parts! You should also have your quattro checked out for damage.
Depending on how far they towed your car; it could be damaged as well! Worth looking into if you ask me...
Old Dec 7, 2007 | 07:05 PM
SAudi's Avatar
Default RE: Oil Pan
try FCP groton on ebay, i know i know ebay but i can vouch for them they come with a 12 month warranty and provide good parts, i actually just bought an lower oil pan for my car, for $65 and $25 oil pan gasket from NAPA.
http://cgi.ebay.com/ebaymotors/New-V...spagenameZWDVW
