Car not starting...please help.
Good afternoon,
I was driving back home tonight when the car just died. The engine turns over, but does not start. I opened the lid over the fuel pump, and can hear it just fine, so I'm not so sure that is the problem. Since it was pretty late, I did not have a chance to check for spark, but will do it first thing tomorrow. I wanted to post tonight so I can hopefully have some ideas posted by the time I start tomorrow. I know this is a very general description, but I thought maybe this car has some kind of recurring issue. Any ideas or recommendations? UPDATE - 12/02/07 1:09PM: I just took out the spark plugs and they are quite soaked in gas, so I believe gas pump is not the issue. Also checked compression, which is great. There is however, no spark on any one of the cylinders. Any suggestions? By the way, the car is a A4 1.8T manual tranny. Mods includes APR chip and k04 upgrade. Thank you very much! |
RE: Car not starting...please help.
probably the coil packs i would assume. did you get a CEL.
No CEL. I don't believe ALL the coil packs would fail at the same time, is that common?
Crank or Cam sensor failure would take away spark across all cylinders, do u have any way to test the sensors?
Not sure, what do I need to test them?
its possible with a dvom, a graphing meter or oscope is better. a vag com should also be able to, but i forget which blocks
I just changed the crank sensor, but still nothing. Could it be the cam sensor?
its not a cam sensor.. a fail cam sensor might stop it from starting, but it wont kill the engine once its running. what year is it? does it have a power output stage, or are the coils ecm controlled directly? if all coils failed at once, im guessing its the power output stage.. aka ignition module. find a local parts dealer, they may be able to test it.
kevin |
Issue fixed! It ended up being the ignition module:-)
| All times are GMT -4. The time now is 06:39 PM. |
