-   -   Bose front Speaker problem (https://www.audiforums.com/forum/electronics-30/bose-front-speaker-problem-84362/)
ultimated Dec 11, 2007 08:36 AM
I've got kind of a weird problem: the front drivers side speaker sounds terrible when its cold, buzzes in lower tones, but returns to normal as the interior warms up. Its in 2001 A4 Avant w/ Bose concert system. I did a search here but didn't find any help. Any clues? Thanks.
A6Bman Dec 11, 2007 03:27 PM
RE: Bose front Speaker problem
speculation: a wire to one of your speakers in that door is only partially connected. As the heat expands the materials around the wire, it regains a full connection. Sounds like you should pop the door pod off and check for a loose wire.
ultimated Dec 13, 2007 08:40 AM
ORIGINAL: A6Bman
Thanks, pardon the newbie question, but does the grill pop off or do I have to remove the entire door panel? 2001 A4 avant.
A6Bman Dec 14, 2007 01:21 PM
No problem! You will have to take the whole door panel off. Its a fairly simple process. Here is your link! http://www.vaglinks.com/Docs/Audi/C5...Front_Door.pdf
go to VAGlinks.com as well...soooooo much info for Audi owners!
