-   -   2005 A6 timing (https://www.audiforums.com/forum/audi-a6-9/2005-a6-timing-91896/)
daredevil1 Feb 17, 2008 02:35 PM
2005 A6 timing
Does a 2005 A6 3.1L have a timing belt, timing chain, or both? Thanks
Kevin Feb 17, 2008 03:59 PM
RE: 2005 A6 timing
timing belt
daredevil1 Feb 18, 2008 10:38 AM
RE: 2005 A6 timing
But this article says it's chain driven:
http://www.dpncanada.com/index.php?o...d=455&Itemid=2
Kevin Feb 18, 2008 05:20 PM
RE: 2005 A6 timing
The 4.2 has a chain, the 3.2 has a belt.
Batteries Feb 18, 2008 05:35 PM
RE: 2005 A6 timing
ORIGINAL: Kevin
Yeah, you're probably right, since you usually are, but it is confusing. That article says that *both* engines (3.2 and 4.2) are chain driven.....?
daredevil1 Feb 18, 2008 06:06 PM
RE: 2005 A6 timing
Oh ok, thanks!
Kevin Feb 18, 2008 07:36 PM
RE: 2005 A6 timing
I have an 05 4.2 that certainly has a timing chain. The generic A6 service manual that came with the car calls for the timing belt in the 3.2 being replaced at 75,000 miles. It is possible that the service manual is wrong, or has a typo, but it does seem to indicate that the 3.2 has a timing belt. However, the 2005 brochure for the 3.2 says that it has a "maintenance free chain drive timingbelt". So the mystery continues.
Batteries Feb 18, 2008 10:23 PM
RE: 2005 A6 timing
Here's the "official" 2005 Audi A6 Sedan Equipment list. As Kevin said, it states that both have a timing chain....?
http://i82.photobucket.com/albums/j2...TimingBelt.png
daredevil1 Feb 28, 2008 06:42 PM
RE: 2005 A6 timing
Even if it does have a chain, how can it be maintenance free? Chains can still wear out and break. And what does chain drive belt mean?
auditech79 Feb 28, 2008 07:10 PM
RE: 2005 A6 timing
Both the 3.2L and 4.2L engines have timing chains. The ONLY motor that still has a timing belt after the year 2005 is the 2.0T, the early model 4.2L A8's still have belts until they upgraded them to FSI 4.2L chain drive motors as well.
The chain would take well over 500 thousand miles before it would ever need service, its no standard steel chain.
