I'm a tad frustrated by how slow a B6 is
Ok so I have done some pretty basic mods to my car, revo chip, forge dv, full catback, Carbino intake and a few other little things. Im in it about 1800-2000 and I still cant beat a Gti with just a catback. I know these are big heavy all wheel drive cars, but by god this thing is just flat out slow. I dunno what to do anymore.... any suggestions under the $1000 mark to speed it up a bit?
RE: I'm a tad frustrated by how slow a B6 is
Big Turbo, injectors, TIP andRevo stage 3. Might get it done for $1k if you find used stuff. You would eventually want FMIC.
But someone will always be faster. |
Yeah, once you swap out turbo then you're talking. I remember the 1 and 1+ days and the car was slow. You'll be happy with a big turbo.
If I go 1+ will I need to front mount it??? also would there be much of a noticleble diff. because they claim 15% increase from 1 to 1+, but we all know how these companies inflate numbers...
You dont need one, but it would be better to have one... You might loose like 1-2psi but eventually your car would run stronger, and much better in a summer then on a stock dsmic. Here is a good info from Papachristou
http://www.audizine.com/forum/showthread.php?t=194522 |
If your still running the stock cat, take that POS out and put in a test pipe. Gotta let that turbo beathe! Should get you another 15-20 horse power if your chipped with REVO software.
Other than that, you need a bigger turbo. |
I wanna throw the TP on so bad but Im afraid of emissions, but my tags are good til jan 2010 though I guess. plus isn't it hard to find a shop to rip the cat off and install the test pipe?
do it u'rself!!! take only a few hours and you get that special feeling inside from knowing you did a good job... i'm going from apr stage 1 to 1+ in 3 days.... i'll let ya kno how it is... current mods are stage 1, test pipe, apr sport catback, snub, full bov... oem clutch:(
| All times are GMT -4. The time now is 09:12 PM. |
