Diode Mod
Has anyone been able to do a MAP clamp Diode mod on a 2.7t? I'm running into an issue with my APR chip, I installed K04 turbos and it and with the K03 chip is goes into soft limp home mode and clips the boost to 10PSI.
Thanks for the assist |
RE: Diode Mod
only thing i can think of is your air meter is WAY off because of the new larger level of forced induction from the k04s ... if it is going into limp mode i dont know what to tell you but i have heard that peoples cars run like crap for the first week and then the ecu adapts ... without tuning k04s are useless ... you should probably get a larger MAF and plugs injectors and fuel pump n they get yourself k04 tuning from vast or giac ... i wouldnt go with apr (if the even have tuning for k04) bc apr isnt a real aggressive chip
if you get tuning itll b 4.0 bar fueling so be prepared to drop some cash at the pump my man lol also monifoldsshould be done (i was lookin at your mod list) and a new hose kits thats a bit thicker bc k04s will blow stock hoses to pieces n you'll be heatsoaked in no time! |
| All times are GMT -4. The time now is 01:12 AM. |
