Diode Mod
Old May 17, 2008 | 08:33 PM
fusnowtiger's Avatar
Default Diode Mod
Has anyone been able to do a MAP clamp Diode mod on a 2.7t? I'm running into an issue with my APR chip, I installed K04 turbos and it and with the K03 chip is goes into soft limp home mode and clips the boost to 10PSI.
Thanks for the assist
Old May 18, 2008 | 12:33 PM
joetm's Avatar
Default RE: Diode Mod
only thing i can think of is your air meter is WAY off because of the new larger level of forced induction from the k04s ... if it is going into limp mode i dont know what to tell you but i have heard that peoples cars run like crap for the first week and then the ecu adapts ... without tuning k04s are useless ... you should probably get a larger MAF and plugs injectors and fuel pump n they get yourself k04 tuning from vast or giac ... i wouldnt go with apr (if the even have tuning for k04) bc apr isnt a real aggressive chip
if you get tuning itll b 4.0 bar fueling so be prepared to drop some cash at the pump my man lol
also monifoldsshould be done (i was lookin at your mod list) and a new hose kits thats a bit thicker bc k04s will blow stock hoses to pieces n you'll be heatsoaked in no time!
CCA4
Feb 7, 2011 09:07 AM
Mevans607
Feb 4, 2008 04:09 PM
1.8TK3MP
Jan 24, 2008 10:41 PM
Red_sapphire89
Jan 15, 2008 03:09 PM
CJRando
Oct 21, 2007 04:51 PM
