-   -   hanging sensor (https://www.audiforums.com/forum/b5-models-69/hanging-sensor-107843/)
Lefty Jul 15, 2008 09:45 PM
hanging sensor
having trouble location where a sensor goes. its hanging under the driver side bumper. it is brown in color and I think the part # is 800 620 535. the numbers are so small I cant read them. any ideas? looks like some kinda air sensor. its on a 1998 A-4 1.8T
ImTheDevil Jul 15, 2008 11:01 PM
RE: hanging sensor
Could be the temp sensor for the ambient temp display on the cluster. If so, it should be secured and mounted behind the bumper in the center of the car, at the base of the radiator. Take a look and see if you have a sensor there.
Mlaubach Jul 17, 2008 01:53 PM
RE: hanging sensor
+1. It's the temp sensor. At the base of the A/C condensor (the radiator-looking thing at the front behind the bumper) is a bracket that also holds on the power steering cooler loop. In the very middle of the car is going to be a circular hole for that sensor. The sensor sits left to right (horizontally) with the wire end to the right as you are facing the car.
MIKE
Lefty Jul 18, 2008 10:05 AM
RE: hanging sensor
thanx guys!!!!
