10v turbo coil problems
Old Jan 16, 2008 | 04:48 PM
boneless's Avatar
Default 10v turbo coil problems
I have a 5000 with the 10v turbo and for the second time when it gets real cold the coil dies. The car will start then die and then there is no spark. This has happened twice now and I traced all the wires for shorts and none found but it just happened again. After I replaced the coil it worked just fine for the last month. Any ideas? It has to be real cold, under 10 degrees F.
Old Jan 17, 2008 | 06:51 PM
sepp's Avatar
Default RE: 10v turbo coil problems
So is the car running OK, after the replacement coil is in place? Even with simular tempratures?
Or are you expieriancing the same problem, with a different unit?
Murph's law
B7 Models
15
Jul 30, 2015 08:54 PM
lancep
Jan 5, 2012 10:34 PM
fi3nom
Jan 3, 2012 11:27 AM
ballredA4
Aug 27, 2008 12:47 AM
amiller86
Feb 23, 2008 08:46 PM
