1985 5000 turbo diesel
Old Dec 8, 2006 | 10:32 PM
123dica's Avatar
Default 1985 5000 turbo diesel
i have a 85 diesel and would like to know what the displacement is and how to find it's markings and how to set the injector timing and valve timing. I would be greatly appreciative if someone could provide this information as noone I've contacted seems to know.
-Heres hoping...Paul
Old Dec 9, 2006 | 12:16 PM
kakarot's Avatar
Default RE: 1985 5000 turbo diesel
valve timing is exactly the same as on the regular gasoline engine. the injector timing, is just like the valve timing, but you play with the pump rather that camshaft.
all you have to do is put engine TDC, and the valve timing thing should point to the begining of the valve cover mark, like the cap of the side of it, its sharp.
and for injectors there should be mark somewhere that you alighn, then you tighten the belt.
Old Dec 11, 2006 | 02:25 AM
InExile's Avatar
ditto ... cam is like gas motor, fuel you mess with the pump
Old Feb 4, 2007 | 10:42 PM
tnkgrl7's Avatar
Thanks for your info. I will send it along to dad(123dica).
puchscooter
Nov 11, 2017 07:03 AM
sneezlsrus
Jan 16, 2012 01:36 AM
taperwil
Mar 11, 2009 11:24 PM
OchoCinco
Jun 23, 2008 12:19 PM
carnexus
Jan 30, 2008 07:35 PM
