1994 Audi 90 Quattro
Old Apr 18, 2005 | 01:23 AM
audicrazy's Avatar
Default 1994 Audi 90 Quattro
I'm considering this Audi and would like to get some feedback from you guys. This is what was in the ad
"Audi 90Q '94 AWD, loaded, runs great, 5 speed, snows & summers, 151k, $4200/best"
The vin checked out fine on carfax. 2 owners. Do you think it is worth it? How long do they usually last (mileage)? Common Problems?
Also I would like you to tell me how much I should make an offer to this guy if you think it is worth it.
Thanks.
Old Apr 19, 2005 | 12:32 PM
0fframp's Avatar
Default RE: 1994 Audi 90 Quattro
Audi's hold up reasonably well, but require quite a bit of maintenance especially given the age and mileage. If you can’t do most of the repairs yourself then I don’t recommend buying any car with more than 100K as quite often small little things creep up and taking it to a mechanic is going to cost you. If the car has been well maintained and some common items (radiator, distributor, struts, shocks, clutch, timing belt, water pump, ball joints, exhaust, head gasket, valve seals, climate control, etc.) have been changed then it might be a good buy. If not you can pretty much expect to be doing them yourself.
rachel krumpelman
Jan 5, 2012 02:23 PM
shoretist
Jun 16, 2010 12:14 AM
debeani
Feb 7, 2009 11:29 PM
fliparto
Sep 26, 2006 06:08 PM
casey38boost
Apr 24, 2006 02:19 AM
