audi 4000 running hot
Old Sep 24, 2005 | 09:16 PM
ocgirl's Avatar
Default audi 4000 running hot
about a month ago i bought an 86 audi 4000s. It runs fine no problems. But it seems to run hot. About 3/4 of the way up. Occasionally it creeps a bit more then this and the temp light blinks on for a second.
The top hose is hot bottom is cool. I figured this meant thermosat. Changed the thermostat and I would say the new t-stat is not opening either. Still running hot.
Any tips?
Old Sep 24, 2005 | 10:57 PM
kakarot's Avatar
Default RE: audi 4000 running hot
what car do you have, engine, year, etc.....
Old Sep 24, 2005 | 11:05 PM
ocgirl's Avatar
86 4000S. Four cyl. 1.8. Sedan
I'm wondering if the tstat is wrong or not working. Maybe I need to go with a different temp tstat.
Old Sep 24, 2005 | 11:13 PM
ocgirl's Avatar
The fans are also not kicking in properly. Right now I'm assuming the problem is the tstat. When I get that working if they're not running I'll check those sensors. Right now I've got them hard wired to run constant until I get this probelme figured out.
Old Sep 24, 2005 | 11:20 PM
kakarot's Avatar
on my VW passat I had a problem, same engine, I bought a new stat but it didn't have a hole in it, so I had a huge air buble inside my engine.
I would recomend taking out thermostat out and cheking it. Sometimes even new is bad.
cheking:
thermostat + boiling water. opens good, doesn't bad. by puting it into water and boil the water at the same time.
Old Sep 25, 2005 | 01:02 PM
audisloff's Avatar
also make sure you don't have a blockage in your engine somewhere, cause if your top hose is hot and bottom is cool that would definitely indicate fluid not passing through the motor
Old Sep 25, 2005 | 05:14 PM
ocgirl's Avatar
pulled the thermostat out and bypassed it. Now it's running right. So I guess I have a defective new tstat. And it's the only one they had in stock.
By the way, it's a pain in the butt to change this tstat.
Old Sep 25, 2005 | 10:41 PM
0fframp's Avatar
It’s been a long time since I had my 4000. What temp is the stat? If you have one that is 80C or 88C drop in a pot of boiling water if it opens up it is not the stat but air trapped under the thermostat or the water pump. Check the manual there might be a special air bleeding procedure.
annen0017
Nov 19, 2014 12:08 PM
crownstables
Aug 4, 2009 02:25 PM
Jo0oshhhh
Mar 21, 2009 02:04 PM
barryjones
Dec 9, 2007 02:34 PM
altairian2000
Jun 12, 2004 05:06 PM
