Audi 80 1990 (b3) just bought - answers needed!!
Hi there! im obviously new here so i thought id say hi...and hit u guys with some questions
just got an 80 b3 and im wondering:
- is it possible to fit the red rear indicator lights from a b4 to a b3? same goes for the front clear ones..
- has any1 replaced the 4" front speakers with 6"? how did u do it??
mm..thats basically it so far, hope someone can help me out!
thanks,
maudi
thanks,
maudi
rear yes but need a rear panel.
front no, unless you have a B4 hood with appropriate lights in already.
Speakers, that would mean cutting. Better just install them somewhere else, like front doors.
hey did you manage to work out if there is a way to close the airway in the car completely? Even when the fan is switched off the air from outside seems to be pumped inside ... so for example when it stinks outside I can't seem to close off the vents apart from manually closing each on the dashboard but even then bit of air comes in through other entry points (legs and windscreen way)... usually there is a switch to flick to internal airflow but no such thingon this car.... ???
Also do you maybe have directional tires on this car?
I do and they make the steering quite annoying ... steering wheel pulls to left or right
at times ...
cheers
at times ...
cheers
