Engine Tapping Noise
Hello everyone!
I need your help. I have 1992 Audi 100S with 2.8L V6 12V with engine noise problem. This only occurs on cold start-up or when car sits for a long time (i.e. over the weekend); it sounds like valve/lifter tapping (after warm-up it goes away; oil pressure very good too). So I did some research and it sounds to me that I have bad oil check valves in engine valley and heads. I cannot find any aftermarket vendor that has them in stock, is this a dealer item? I hope not, lol. Can anyone help?
Thanks, Adis
P.S. Car had 102K miles on it.
Thanks, Adis
RE: Engine Tapping Noise
I think I had the same problem ('93 audi 90s). It was actually the water pump bearing, but I started noticing leaks after a month or two.
I took her to AutoZone and the guy said: "It sound like a normal BMW motor!" ...wtf?
you can use tranny oil to flush the engine, but that wont help the lifters, the oil will not clean out the lifters. Nothing does. I use 0w-40 and that keeps my lifters quit, even on cold days, I will hear 2 3 clicks and its gone. thats after parked for a week.
thanks avant80, I did reasearch, large reaserach. the 0w40 will behave same as 10w-40 or 5w-40. it just has better cold behavior that any other I saw. Thank you mobil, dont screw up.
You can see my research, if you click on the link in my sig, and on the bottom of the page click "Oil" thats all, read on like 5 or 7 pages long
