idling issue urgently needed info
Old Oct 26, 2005 | 09:57 PM
mikerike's Avatar
Default idling issue urgently needed info
Folks,
I have a1991 Audi 100 5 cylinder. Is there any explanation why my motor idles up and down similar to oscillating
the car runs fine other than that issue.
Please reply ASAP
[8D]
Mikerike
Old Oct 26, 2005 | 11:04 PM
0fframp's Avatar
Default RE: idling issue urgently needed info
Probably the ISV is dirty.
Old Oct 27, 2005 | 07:28 AM
mikerike's Avatar
Offramp
Could you give me a clue as to what it looks like and location.
I have ordered a service manual but it has not arrived yet.
Your assistance is greatly appreciated.
mikerike
Old Oct 27, 2005 | 01:28 PM
0fframp's Avatar
ISV location.
[IMG]local://upfiles/1095/3749BAFF04E4439F85566152AEF4DC4F.jpg[/IMG]
Old Oct 27, 2005 | 09:11 PM
mikerike's Avatar
Offramp
Thank you for valued information. Very easy to locate and get to.
What would be the proper procedure to clean the ISV.
It appears that the electrical connector should be disconnected and it appears that the rubber boot should slide off.
I should be able to clean the unit with NO flash-- an elctrical contact cleaner.
Does this sound correct.
Thank again for your assistance,
mikerike
Old Oct 27, 2005 | 10:56 PM
0fframp's Avatar
I would use brake or electrical contact cleaner first, if that doesn't help try using carb and choke cleaner. Plug one hole spray some cleaner, plug the other and shake it a few times, pour the contents out and repeat a few more times until clear cleaning agent comes out. Don't poke inside with anything as this can cause the vane to stick. If you do a search on this forum you will find plenty of suggestions and discussions.
gilliethakidd
Jul 4, 2011 02:37 PM
Girlofthenight
Mar 14, 2009 04:31 PM
retiltxet
Jul 27, 2008 03:44 PM
27rich
May 7, 2007 09:37 AM
OriginalG
Feb 28, 2006 12:32 AM
