Just bought a used Audi
Old May 11, 2004 | 04:24 PM
Crevalle's Avatar
Default Just bought a used Audi
I just purchased a '91 Audi 80 with 178k miles. Runs very well, and is still in quite good shape. I paid $325, so I'm willing to put a little cash into it for improvements. I will be installing a new starter this weekend, as well as the below items:
air filter
oil filter (and corresponding oil change)
spark plugs
distributor cap/rotor
wire harness
Just wondering what else you think I should do. Do Audis have a propensity to have anything in particular go wrong that I should be watching out for? In other words, Saabs often have problems with the idler pulley and the direct ignition cassette--does Audi have any similar I should look out for?
Old May 12, 2004 | 04:23 PM
0fframp's Avatar
Default RE: Just bought a used Audi
Don't forget all your belts especially timing. Water pump and belt idler/tensioner is one more area to check. Also check for leaks, older Audi's are notorious leakers. If it's liquid it will probably leak. Radiators and heater cores have plastic sides and are prone to cracking. Expansion tank is another, like I said check for leaks.
johnrhopkins
Oct 15, 2014 02:57 PM
soraflair
Jan 27, 2011 07:02 PM
jamezz23
Oct 13, 2010 10:44 AM
shane
May 6, 2005 03:23 AM
Audidriver224
Mar 31, 2004 01:02 PM
